1998 Chevy Cavalier Slightly high engine temperature
PHILOPATOR
  • 1998 CHEVROLET CAVALIER
  • 4 CYL
  • 108,000 MILES
I suspect that i'm having a slight problem with my engine temperature. It used to be exactly 90C on open road and slightly higher in traffic.
Now I noticed that it's about 92C-93C on open road.
Can it be termostat? Should I change coolant?
I'm a little afraid of flush because I suspect having a small leak and don't want to make it worse with the pressurized flush.
Thanks,
Philopator.
Sunday, July 12th, 2009 AT 4:20 PM
Try the thermostat it controls the engine temperature
Sunday, July 12th, 2009 AT 4:51 PM
PHILOPATOR
Understand, thanks.
By the way, could quality of the coolant also affect the temperature? It hasn't been changed for over 100K miles.
Monday, July 13th, 2009 AT 7:12 AM
Replace the coolant/thermostat and then bleed the cooling system.
Monday, July 13th, 2009 AT 12:24 PM
