1998 Chevy Cavalier POWER STEERING PUNP
SKIMPY
Steering problem
1998 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
HOW TO DISEMBLE POWER STEERING PUMP AND REPLACE
Oct 29, 2008 at 12:43 AM
  • 110,248 POSTS
Hi:
To remove the power steering pump, first disconnect the battery. Next, remove both the high and low pressure hoses from the pump. Next, remove the serp belt. Finally, remove the bolts and the pump. Reverse the order to replace.
This can be a tough job on this car. You may want to purchase a manual for your car. It may be helpful to you.
Oct 31, 2008 at 5:24 AM
