1998 Chevy Cavalier p0480
141,000 MILES • 4 CYL • FWD • AUTOMATIC
SCOTT5976
my check engine light came on so i checked it and the code said p0480 which i found out means a fault with a relay switch for the cooling fan. i changed the relay switch in the fuse box under the hood and the check engine light is still on
Oct 20, 2009 at 3:42 PM
MMPRINCE4000
  • 8,548 POSTS
Cooling fan relay is in engine compartment in fuse/relay/fuseable link box. It should be marked on plastic cover.
Oct 21, 2009 at 2:06 AM
