1998 Chevy Cavalier P0420 code
BSTASH143
  • 1998 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 108,000 MILES
I am still receiving a p420 code after replacing the entire exhaust system including the exhaust pipe, cat converter, O2 sensors before and after the cat converter and the muffler what else can I do to clear this code so I can pass emissions testing?
Monday, October 19th, 2009 AT 11:52 PM
MMPRINCE4000
  • 8,548 POSTS
Did you reset code with a scanner?
If so, what type of convertor did you use, factory or universal?
Assuming everything you installed is working, then it is either an Air/Fuel ratio problem (lean/rich), or the PCM is defective.
Tuesday, October 20th, 2009 AT 9:58 AM
