1998 Chevy Cavalier Overheating.
97,965 MILES • 4 CYL • FWD • AUTOMATIC
TONY TOGNONI
Where do I find the coolant air bleed valve? I've just replaced water pump and thermostat, flushed cooling system and continualy get possabe air lock and overheating problems when filling with new antifreeze. I have a Chilton manual but picture of bleed valve is not right. Do have a bleed valve on bypass tube (to heater core) and tried bleeding there but manual say's not to use this port.
Nov 15, 2009 at 10:27 AM
  • 110,251 POSTS
I believe it is located on or near the thermostat housing.
Nov 24, 2009 at 2:25 PM
