1998 Chevy Cavalier Overheating
132,000 MILES • 4 CYL • 2WD • AUTOMATIC
DARLANGLE
have had the head gasket replaced the thermostat 3 times the water pump twice the fan motor checked coolant sensor replaced the cooling gage replaced the radiator replaced and the heads machined. This car is still running hot. and belive it or not it seems to run hotter when I turn on the heater. I have also noticed some grey smoke coming out of the tail pipe. Please give me some advice I am out of resources. Please Help Thanks so much
Oct 30, 2008 at 5:17 AM
  • 110,251 POSTS
Hi:
Have you had the radiator flushed or rodded out? Also the engine coolant temp sensor may be bad. It could cause the vehicle to think it's below 0 degrees and the car could run too rich.
Let me know what you find.
Oct 31, 2008 at 3:50 AM
