Where do I find the coolant air bleed valve? I've just replaced water pump and thermostat, flushed cooling system and continualy get possabe air lock and overheating problems when filling with new antifreeze. I have a Chilton manual but picture of bleed valve is not right. Do have a bleed valve on bypass tube (to heater core) and tried bleeding there but manual say's not to use this port.
Nov 15, 2009 at 10:27 AM
