1998 Chevy Cavalier Overheating
220,000 MILES • 4 CYL • 2WD • AUTOMATIC
MANDIGI
I have a chevy cavalier which is running high on milage but still drives very well. The problem I have is that it overheats periodically when I ser the AC to heat and now it is showing the sign of oil pressure. My mechanic does not seem to get the problem. I keep adding anti freeze but I donot want it to go on like that. What could the problem be?
Feb 4, 2009 at 6:55 PM
RHALL77
  • 3,361 POSTS
if you keep adding anti freeze you need to have the system pressure checked to find out where the leak is at. may be a possible water pump or head gasket
Feb 4, 2009 at 11:24 PM
