1998 Chevy Cavalier over heating
128,000 MILES • 4 CYL • 2WD • AUTOMATIC
GODBEY6983
i've changed the head gasket last summer 07, changed the water pump, thermostat,flushed the system.no visible leaks.... no clue what to do almost a min. or two being on it gos straight to hot please help thx
Apr 23, 2008 at 9:04 AM
GTRGILBERT541
  • 14 POSTS
[quote:f96990ed91="godbey6983"]Engine Cooling problem
1998 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 128000 miles
i've changed the head gasket last summer 07, changed the water pump, thermostat,flushed the system.no visible leaks.... no clue what to do almost a min. or two being on it gos straight to hot please help thx[/quote:f96990ed91]
when it goes straight to hot is the motor actually hot, it may just be the coolant temperature sensor that is inaccurate
Apr 23, 2008 at 3:35 PM
ROB2008
  • 258 POSTS
A couple things you could do is inspected the fan and and make sure it's running or check the radiator hose if there worn they can collapse and cause the thermostat to stay closed .
Apr 23, 2008 at 4:34 PM
