1998 Chevy Cavalier Not blowing any air
1998 CHEVROLET CAVALIER
213,000 MILES • 4 CYL • 2WD • AUTOMATIC
JUANITA GUTIERREZ-RICO
I recently purchased an a/c control switch to replace the circuit board i thought burned out but after replacing any parts that I thought may have been bad, there is very little to no air blowing through the vents. What do I need to look for to repair this problem?
Mar 30, 2010 at 1:58 AM
LEGITIMATE007
  • 5,121 POSTS
well check the for any bad vacuum hoses going into the firewall near the heater core area, are you talking about air volume or just no hot air
Mar 30, 2010 at 2:02 AM
lack of air pressure ... actually none. I replace the electrical components that were bad behind the left and right switches and i have no airflow. Could there be some type of reset that I am missing or is it my blower or ??? Help me please!
Mar 30, 2010 at 3:37 PM
LEGITIMATE007
  • 5,121 POSTS
can you hear the fan come on?
Mar 30, 2010 at 3:45 PM
No the fan is not coming on...I didn't know if there was a reset after changing out the components of the control switches. Any help you can give me will be greatly appreciated. Thanks!
Mar 31, 2010 at 1:50 AM
LEGITIMATE007
  • 5,121 POSTS
if the fan does not come on then the fan resistor is faulty and need replacement
Mar 31, 2010 at 2:41 AM
