1998 Chevy Cavalier main axle seal on the motor
ROBERTS13
  • 23 POSTS
Drive Train Axles Bearings problem
1998 Chevy Cavalier Front Wheel Drive Automatic
how do i remove it and is there two c ring clips holding it on?
Oct 24, 2010 at 7:11 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Are you asking about the seal where axle enters transaxle?
Let me know
Thanks for donate
Oct 24, 2010 at 7:44 AM
ROBERTS13
  • 23 POSTS
no the one on the motor the seal kit has two different seals
Oct 24, 2010 at 7:55 AM
ROBERTS13
  • 23 POSTS
when i removed frist part of seal transmisson fluid ran out
Oct 24, 2010 at 8:06 AM
DOCFIXIT
  • 18,828 POSTS
See diagram shows both axles and seals is this what your doing
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_669.jpg
Oct 25, 2010 at 8:03 AM
ROBERTS13
  • 23 POSTS
im doing the seal that where the left drive shaft connects to the motor
or transmission
Oct 26, 2010 at 12:34 AM
DOCFIXIT
  • 18,828 POSTS
Seal is driven into trans. has metal case and lip seal with garter spring to hold tight to axle. Seal can be removed with a seal puller and sometimes a screwdriver. Some fluid will come out . The two seals maybe for left and right sides they are different. Not sure what you mean by first part of seal? can you post a PIC?
Oct 26, 2010 at 4:29 AM
ROBERTS13
  • 23 POSTS
its all the one seal but two different peices
is there two clips keeping the part that is driven into the transmission
Oct 26, 2010 at 10:19 AM
ROBERTS13
  • 23 POSTS
this part around the shaft is what i am trying to remove
https://images.2carpros.com/forum/automotive_pictures/578494_101_0704_1.jpg
Oct 27, 2010 at 7:59 AM
ROBERTS13
  • 23 POSTS
this is the new one from new seal kit but this is what i am trying to remove
https://images.2carpros.com/forum/automotive_pictures/578494_101_0705_1.jpg
Oct 27, 2010 at 8:14 AM
DOCFIXIT
  • 18,828 POSTS
That is the output shaft the clip is what holds axle on. The oil seal goes around and seals on axle trace there is no need to replace clip when replacing seal. What is on table don't know. Was problem oil leak or CV joint problem?
Oct 27, 2010 at 10:19 AM
ROBERTS13
  • 23 POSTS
this is what i need to replace if you know what this is can you please tell me
https://images.2carpros.com/forum/automotive_pictures/578494_101_0707_00_1.jpg
https://images.2carpros.com/forum/automotive_pictures/578494_101_0708_1.jpg
https://images.2carpros.com/forum/automotive_pictures/578494_101_0709_1.jpg
https://images.2carpros.com/forum/automotive_pictures/578494_101_07041_1.jpg
Oct 27, 2010 at 12:55 PM
DOCFIXIT
  • 18,828 POSTS
Oil seal is item top left other stuff has nothing to do with axle oil seal. Where did you get? part number? name of kit?
Oct 31, 2010 at 6:54 AM
ROBERTS13
  • 23 POSTS
got parts from gm dealership part number 24203910
name seal kit
Nov 1, 2010 at 7:24 AM
DOCFIXIT
  • 18,828 POSTS
GM part number for axle seal 24233355. Again what was problem oil leak? CV failure? what???
Nov 1, 2010 at 8:29 AM
M3RT3N
That cupped seal is pressed on just ran into that problem taking it to mechanic
Oct 31, 2016 at 9:02 AM
