1998 Chevy Cavalier Low power
GRANDMA D
  • 1998 CHEVROLET CAVALIER
  • 6 CYL
  • FWD
  • 225,000 MILES
The transmission lacks power from what it had. The RPM only ever goes up to about 2500. Otherwise runs OK. We have changed out a front wheel bearing recently, and did have some transmission oil leak out (which has been refilled) it seemed to be a seal I believe? Anyway, this low power had started prior to that repair. How do I go about finding out what the problem is?
Sunday, September 12th, 2010 AT 2:39 PM
  • 109,885 POSTS
Has the check engine light come on? Have you checked fuel pump pressure?
Tuesday, September 14th, 2010 AT 7:09 AM
GRANDMA D
Thanks for responding. No check engine light comes on. How do you check the fuel pump pressure? Will it have to go to the GM dealer and have that checked on the computer system? What would that cost (on average)?
Tuesday, September 14th, 2010 AT 6:46 PM
  • 109,885 POSTS
The fuel pump is easy to check. You will need a fuel pressure gauge. Most parts stores will lend or rent the gauge to you. Here is a how to.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Tuesday, September 14th, 2010 AT 8:31 PM
Related Engine Low Power Content
