1998 Chevy Cavalier intermitten no crank security light fl
212,000 MILES • 4 CYL • FWD • AUTOMATIC
EJ71
what would be the most likely cause there no trouble codes if it sits for 30 minutes it will start
Mar 28, 2010 at 1:32 PM
MMPRINCE4000
  • 8,548 POSTS
Try resetting the security system:
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position.
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it.
Mar 31, 2010 at 1:15 AM
