1998 Chevy Cavalier ignition switch
ROB_USN2006
Electrical problem
1998 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
I purchased the car and there was no key for the ignition, you don't need a key to start it just turn the inter key ignition, i replaced it and you still don't need a key. you have to disconnect the battery every time your done driving it cause the battery will drain because it will not turn all the way to the off position and all the instrument cluster lights stay on, if i get a factory key made will this fix my problem and allow it to turn to the off position??
Oct 17, 2008 at 1:20 PM
RHALL77
  • 3,361 POSTS
i would advise taking it in and having the lock cylinder installed properly and aligning the ingnition switch correctly. this should help your problem
Oct 21, 2008 at 12:44 AM
