1998 Chevy Cavalier I smell gas
1998 CHEVROLET CAVALIER
182,000 MILES • 4 CYL • 2WD • AUTOMATIC
PUNKSTER07
It seems like when I use my heat and am sitting at a stop light my car smells like gas. If I turn off heat smell goes away and also when I am moving I do not smell gas either?
Any ideas?
Apr 26, 2008 at 2:49 PM
BUZZSAW
  • 1,198 POSTS
[quote:55351f3e11="punkster07"]Smells problem
1998 Chevy Cavalier 4 cyl Two Wheel Drive Automatic 182000 miles
Any ideas?[/quote:55351f3e11]
is it only the heat or AC also? what about when you open the hood do you smell gas?
the air intake for the heater is on the pass side up by the front windsheild, better ck it out so something doesnt catch on fire
Apr 26, 2008 at 3:00 PM
PUNKSTER07
I have not had to use the A/C for sometime I live in MN so I am not sure. But I can smell gas when I get out of my car too.
Apr 26, 2008 at 3:10 PM
PUNKSTER07
I have been told that maybe it is an underhood fuel leak or more likely a leak in the evaporative emissions system that vents fuel tank
Apr 26, 2008 at 3:11 PM
BUZZSAW
  • 1,198 POSTS
[quote:d40b4367a2="punkster07"]I have been told that maybe it is an underhood fuel leak or more likely a leak in the evaporative emissions system that vents fuel tank[/quote:d40b4367a2]
if something in the vent sys was bad a ck engine light would be on
really get this checked out, dont want to see a fire
a fuel rail or an injector seal may be the problem
Apr 26, 2008 at 3:16 PM
PUNKSTER07
Yeah my check engine light is on and has been on for a long time before this smell appeared. Why does it only smell like gas when heat is on and I am idling???
Thanks for the advice I will have to get it checked out soon!
Apr 26, 2008 at 3:29 PM
BUZZSAW
  • 1,198 POSTS
[quote:31290fd243="punkster07"]Yeah my check engine light is on and has been on for a long time before this smell appeared. Why does it only smell like gas when heat is on and I am idling???
Thanks for the advice I will have to get it checked out soon![/quote:31290fd243]
because the heater vent for outside air is just on top of the engine in the firewall, and you also said it smelled like gas when you got out of the car.
please dont drive the car
Apr 26, 2008 at 6:52 PM
