How do I remove the front hub and bearing from the steering knuckle that is rusted in?
Mar 14, 2009 at 7:45 AM
MERLIN2021
✓Experienced Mechanic
Remove the axle nut, remove caliper, seperate lower ball joint, pull axle out of the hub, remove three bolts holding hub to knucle and if you have to, drive it out from behind with a two hammers, place one hammer in the inner part of the hub and hit it with the other one...
Mar 14, 2009 at 8:00 AM
JMZA3080
MEMBER
how do I separate lower ball joint? I have gotten a small gap to get to the back side of the hub, but not sure a hammer will fit in it.
Mar 14, 2009 at 8:11 AM
MERLIN2021
OK do you have the three bolts out? If yes and the axle nut is off, just use a slide hammer and pulley at the front side, attach it to the lug nuts and pull that way! If there is a speed sensor at the hub, disconnect it and get it out of the way...
Mar 14, 2009 at 8:42 AM
JMZA3080
MEMBER
Yes i do, but now the front portion of the hub has come off and I cannot get the rest of it to separate from the knuckle.
Mar 14, 2009 at 9:01 AM
MERLIN2021
They are not pressed in so put a bearing hook on the puller and keep pulling!
Mar 15, 2009 at 12:46 AM
JMZA3080
MEMBER
thanks, it was really rusted in. Job is done, and car is driving fine now. once again, thanks..
