1998 Chevy Cavalier Hub and bearing assembly
1998 CHEVROLET CAVALIER
165,000 MILES • 4 CYL • FWD • AUTOMATIC
JMZA3080
How do I remove the front hub and bearing from the steering knuckle that is rusted in?
Mar 14, 2009 at 7:45 AM
MERLIN2021
  • 17,250 POSTS
Remove the axle nut, remove caliper, seperate lower ball joint, pull axle out of the hub, remove three bolts holding hub to knucle and if you have to, drive it out from behind with a two hammers, place one hammer in the inner part of the hub and hit it with the other one...
Mar 14, 2009 at 8:00 AM
JMZA3080
how do I separate lower ball joint? I have gotten a small gap to get to the back side of the hub, but not sure a hammer will fit in it.
Mar 14, 2009 at 8:11 AM
MERLIN2021
  • 17,250 POSTS
OK do you have the three bolts out? If yes and the axle nut is off, just use a slide hammer and pulley at the front side, attach it to the lug nuts and pull that way! If there is a speed sensor at the hub, disconnect it and get it out of the way...
Mar 14, 2009 at 8:42 AM
JMZA3080
Yes i do, but now the front portion of the hub has come off and I cannot get the rest of it to separate from the knuckle.
Mar 14, 2009 at 9:01 AM
MERLIN2021
  • 17,250 POSTS
They are not pressed in so put a bearing hook on the puller and keep pulling!
Mar 15, 2009 at 12:46 AM
JMZA3080
thanks, it was really rusted in. Job is done, and car is driving fine now. once again, thanks..
Mar 16, 2009 at 11:24 AM
MERLIN2021
  • 17,250 POSTS
OK your welcome, well done!
Mar 17, 2009 at 5:38 AM
