My horn stopped working. I changed the fuse
IRISHK9
  • 1998 CHEVROLET CAVALIER
My horn stopped working. I changed the fuse and that isn't the problem. What else can it be?
Sunday, February 1st, 2009 AT 3:03 PM
JDL
  • 16,098 POSTS
The fuse circuit should be hot all the time, cig fuse. Even if the fuse is good, if the circuit isn't hot, it won't matter. You might look at the horn relay, my info says it is in the convenience center, no exact location. You can look under the dash driver side.
There might be a problem with the wiring circuit in the steering column.
Sunday, April 25th, 2021 AT 11:39 AM
IRISHK9
Thanks so much. Your info helped.
