1998 Chevy Cavalier head lights
HUNTERPONY
1998 Chevy Cavalier
The headlights on my daughter's car are not working. The brights work but not the regular lights, either the driving that come on automatically when you start the car or the regular driving lights, just the brights.
We pulled the bulbs and they are not burned out, any suggestions?
Jul 11, 2009 at 5:04 AM
JDL
  • 16,098 POSTS
Hello, your headlamp switch is on the ground circuit for the headlamps. I suspect the problem is there, or the wiring circuit.
The dark blue wire for low beams is ground. I suspect if you use a jumper to ground, the low beams will work.
Jul 11, 2009 at 6:04 AM
