1998 Chevy Cavalier Head gasket
HERBERT
Engine Mechanical problem
1998 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
How to replace a head gasket?
Oct 4, 2008 at 9:26 AM
MERLIN2021
  • 17,250 POSTS
NOTE: When removing valve train components, keep them in order to ensure installation in same location.
Release fuel system pressure. See FUEL PRESSURE RELIEF . Disconnect negative battery cable. Remove air cleaner and intake duct. Remove serpentine drive belt. Remove upper engine mount. Remove intake manifold. See INTAKE MANIFOLD . Remove exhaust manifold. See EXHAUST MANIFOLD .
Drain cooling system. Remove valve cover, rocker arms and push rods. Remove generator rear brace and generator. Remove power steering pump and set aside with lines attached. Remove radiator inlet pipe. Remove ignition coil assembly and accessory bracket. Remove spark plug wires.
Release fuel system pressure. Disconnect negative battery cable. Remove air intake duct. Disconnect exhaust pipe from exhaust manifold. Remove serpentine belt. Drain cooling system. Remove power steering pump and set aside with hoses attached. Remove exhaust manifold.
Remove upper radiator hose and disconnect heater hoses from heater core. Remove rear generator bracket and generator. Remove cooling fan and serpentine belt idler pulley. Remove heater hose pipe bracket bolt from cleaner outlet resonator bracket and remove thermostat housing. Remove accessory bracket. Remove valve cover, rocker arms and push rods. Disconnect fuel lines from fuel rail. Remove cylinder head bolts. Remove cylinder head.
Inspection
Inspect cylinder head for warpage at head gasket surface and manifold surfaces.
DO NOT remove more than .010 (.25 mm) of material from head gasket surface.
Oct 4, 2008 at 9:50 AM
