I would suspect a wheel bearing issue or a issue with the cv joints.
To check the cvs drive slowly and turn left and right sharply but slowly working the vehicle through its range of motion. Try it in reverse also.
For wheel bearings jack up the vehicle and check for movement in the wheel, if you feel any movement the bearings should be checked.
SPONSORED LINKS
Monday, June 30th, 2008 AT 7:28 AM
