I pulled the 10 amp fuse for the cluster out and it was good went to put it back and it blew. Tried several times same results. Disconnected the neg bat cable and same results. If there is a short, then why didn't it blow before I took it out? What else can I check.
SPONSORED LINKS
Tuesday, May 4th, 2010 AT 6:21 PM
