How do I replace the front wheel bearings
KEVINWENDTT
how do i replace the front wheel bearings
Oct 13, 2008 at 10:08 AM
IMPALASS
  • 3,112 POSTS
Hello, hope this helps. FRONT HUB/BEARING REMOVAL PROCEDURE Tools Required: J 28733-B Front Hub Spindle Remover Remove the drive axle. Remove brake caliper bolts and support caliper. Remove the rotor.
https://images.2carpros.com/forum/automotive_pictures/248015_1_1.gif
Remove the bolts (1) from the hub and bearing assembly (3).
https://images.2carpros.com/forum/automotive_pictures/248015_2_1.gif
Remove the hub and bearing assembly (1) from the steering knuckle (2). INSTALLATION PROCEDURE
https://images.2carpros.com/forum/automotive_pictures/248015_3_1.gif
1. Install the hub and bearing assembly (1) into the steering knuckle (2). NOTICE: Always use the correct fastener in the proper location. When you replace a fastener, use ONLY the exact part number for that application. The manufacturer will call out those fasteners that require a replacement after removal. The manufacturer will also call out the fasteners that require thread lockers or thread sealant. UNLESS OTHERWISE SPECIFIED, do not use supplemental coatings (paints, greases, or other corrosion inhibitors) on threaded fasteners or fastener joint interfaces. Generally, such coatings adversely affect the fastener torque and joint clamping force, and may damage the fastener. When you install fasteners, use the correct tightening sequence and specifications. Following these instructions can help you avoid damage to parts and systems.
https://images.2carpros.com/forum/automotive_pictures/248015_4_1.gif
2. Install the hub and bearing bolts (1) and washers (2). Tighten Tighten the bolts to 95 Nm (70 ft. lbs.) . 3. Install the rotor. 4. Install the brake caliper and bolts.. 5. Install the drive axle.. 6. Check the front wheel alignment.
May 4, 2021 at 6:47 AM
