1998 Chevy Cavalier Engine/electrical problem
220,000 MILES • 4 CYL • FWD • AUTOMATIC
SHERRYB437
I have a 1998 chevy cavalier with 220,000. I had an alternator and battery replaced about 4 months ago. The main engine wire was replaced last night. My car started with a jump but does not keep its charge. It stalls when it is being jumped and when I try to restart it the car is dead. No clicking, nothing. While the car was being jumped all the lights flashed on and off including the head lights. Then it went dead. My son thinks it is the CPU unit gone bad. Could this be the case? If so, is it expensive to fix and hard to replace?
Sep 30, 2010 at 1:41 AM
WRENCHTECH
  • 20,760 POSTS
No, your son is incorrect.
Have you tested the battery again?
Have you manually charged the battery before trying to start the car?
Have you measured the charging voltage across the battery with the engine idling and no accessories on?
Have you checked for power at the main terminal of the alternator with the key OFF?
Please make sure all these things have been done and post the results.
Sep 30, 2010 at 2:10 AM
