I have replaced the wheel bearing and i still have a grinding sound while driving and even worse when the wheel is turned. is it possable im having cv joint or shaft problems? i noticed that there is some greese or somthing coming out of where my shaft connects with the motor. I also noticed my wheel is hard to turn if jacked up. the other side was not as stiff and turned fine.
Jan 19, 2009 at 8:33 AM
