Monday, January 19th, 2009 AT 4:33 PM
I have replaced the wheel bearing and I still have a grinding sound while driving and even worse when the wheel is turned. Is it possable im having cv joint or shaft problems? I noticed that there is some greese or somthing coming out of where my shaft connects with the motor. I also noticed my wheel is hard to turn if jacked up. The other side was not as stiff and turned fine.
