1998 Chevy Cavalier Clutch interlock switch
123,254 MILES • 4 CYL • 2WD • MANUAL
JESUSWON1
can anyone tell me how to remove the clutch interlock switch from my cavalier? My starter won't engage with the clutch pressed all the way to the floor, and I've traced the problem to this switch, but cannot find attachment points to remove it... is it a clip, a tab, a screw?? such a tight spot to get into!
Thanks!
Jan 22, 2009 at 2:02 AM
MMPRINCE4000
  • 8,548 POSTS
A bracket holds the switch so that when the clutch pedal is normally not depressed, the clutch pedal arm hits it and closes the circuit. Look at the clutch pedal arm, you should see it, push the pedal by hand, you should see it contact the switch.
https://images.2carpros.com/forum/automotive_pictures/108325_100360_1.jpg
Jan 23, 2009 at 12:09 AM
