Engine Performance problem
1998 Chevy Cavalier 4 cyl Front Wheel Drive Automatic 111k miles
When the engine is below ideal temp it chokes when the pedal is depressed and then after a few seconds of choking it will immediately gain RPM. and it also takes very very long to warm up in hot days
i have changed oil, spark plugs, air filter and kept injector cleaner with no use.
engine works perfectly fine when on ideal temp.
thanks
thanks
Dec 20, 2009 at 5:56 AM
