1998 Chevy Cavalier Car wont park
PPOCKET119303
1998 Chevy Cavalier
My cark will not stay in park. I was using the parking break but even that is not enough. Now i have to put a brick at the tires in order to keep the car parked. What could be the issue and how much should it cost to repair?
Feb 10, 2009 at 12:44 AM
MMPRINCE4000
  • 8,548 POSTS
Check the cable connection to trans, the cable attachment bolt may have come loose, or a bracket may be loose or broke.
If OK then remove console and check cable at shifter.
The other possibility is that the parking "pawl" in the trans is broke, but I would think the cable is most likely the cause.
Feb 10, 2009 at 1:04 AM
