HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Cavalier
Drivetrain
Transmission
Symptoms
Not Shifting
1998 Chevy Cavalier
JES2157
MEMBER
1998 CHEVROLET CAVALIER
4 CYL
FWD
AUTOMATIC
144,000 MILES
Transmission won't shift into higher gear will of up to 35mph then you can hear it whine no promblem with reverse
Wednesday, September 30th, 2009 AT 9:10 AM
MMPRINCE4000
MECHANIC
You can check the fluid level in trans. With engine running in park.
If OK, then the problem is a hydraulic pressure problem, or shift solenoid and you would need to take to trans shop.
SPONSORED LINKS
Thursday, October 1st, 2009 AT 10:25 AM
Please
login
or
register
to post a reply.
Related Transmission Not Shifting Content
Transmission
It's An Automatic Transmission. The First Problem Started Out With The Check Engine Light. I Thin Brought Out My Ecu Scanner To Detect The...
Asked by
kaltora081
1 ANSWER
1998
CHEVROLET CAVALIER
1992 Chevy Cavalier Transmission Not Shifting Out Of...
1992 Cavalier 2.2 Automatic. Transmission Will Not Change Gears. I Can Shift It From Neutral To Drive And Feel It Bump, But It Stays In Low...
Asked by
vareha
1992
CHEVROLET CAVALIER
Transmission Wil Not Shift Back Down Once You Slow...
Okay So I Have An 87 Chevy Cavalier. 4cyl. 3 Speed Automatic Transmission. The Car Runs Great And The Transmission Shifts Up And Works Well...
Asked by
kilroy2215
1 ANSWER
1987
CHEVROLET CAVALIER
When Car Gets Up To About 3,000 Rpm's It Will Not...
Hi There, Thanks For The Recent Question About My Car. I Have Another Problem With My Car Listed Above (1998). I Wanted To Know What Est...
Asked by
boolover34
2 IMAGES
CHEVROLET CAVALIER
1997 Chevy Cavalier Transmission Not Shifting
Transmission Problem 1997 Chevy Cavalier 4 Cyl Front Wheel Drive Automatic My Transmission Is Not Shifting Out Of 1st Gear, It Start...
Asked by
jromajusa
1 ANSWER
1997
CHEVROLET CAVALIER
VIEW MORE
SPONSORED LINKS
Transmission Turbine Sensor Replacement
Transmission Speed Sensor Replacement Honda
Throwout Bearing - Secondary Cylinder Replacement
Online car repair manuals
