1997 Chevy Cavalier 4 cyl Front Wheel Drive Manual
I changed starters now it wont start, question is there more than one starter that will bolt up turns over fine plugs are firing, getting plenty of fuel. With 12 volt test light held on wiring harness for injectors when key is on test light up untill you crank motor then goes out. Does this car have an emergency fuel shut off, if so where is it located
SPONSORED LINKS
Friday, March 26th, 2010 AT 10:17 AM
