1997 Chevy Cavalier water pump, belt
80,000 MILES • 4 CYL • FWD • AUTOMATIC
97CAVALIER
previous question was concerning the water pump not working, removed discharge hose at back of cylinderhead while engine running, no water discharge yet resivour is full, what water was there was hot. Removed Pump seems ok, is possible that belt was routed wrong after it came off, reinstalled by another person? Pump running backwards??
Oct 11, 2009 at 10:04 PM
MMPRINCE4000
  • 8,548 POSTS
The other problem may be that if the pump has a plastic impeller, it may have come loose from drive shaft, rendering the pump useless.
Oct 12, 2009 at 1:33 AM
