1997 Chevy Cavalier tranny leak
200,600 MILES • 4 CYL • FWD • MANUAL
CHAZZ304
i have a slight transmission leak and i dont know what its from.... i recently had a clutch put in my car and the people that worked on it had to drop the transmission to put it in.. now i have a slight transmission leak .. can anyone tell me what they did to it and what i can do to fix it ?? thanks
Apr 2, 2009 at 5:10 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:3aa083d051="chazz304"]Transmission problem
1997 Chevy Cavalier 4 cyl Front Wheel Drive Manual 200600 miles
i have a slight transmission leak and i dont know what its from.... i recently had a clutch put in my car and the people that worked on it had to drop the transmission to put it in.. now i have a slight transmission leak .. can anyone tell me what they did to it and what i can do to fix it ?? thanks[/quote:3aa083d051]
Have you crawled under it to see if you can tell were it is leaking? If not do so, here are the most likely places...
Follow the CV Axles to the tranny there are seals were they go into it on both side.
Look were the tranny and engine block go together if it is leaking in that area it is likely to be the front seal on the tranny. And the tranny would have to come back out to fix.
Also check the drain and fill plugs, they may not have been tightened properly.
Apr 2, 2009 at 5:28 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Also Please do not post more than Once. If you are in a hurry or need a fast answer donate a few bucks and get your answer faster.
Apr 2, 2009 at 5:31 AM
