ign timing is 15 deg at idle, by 1500 rpm timing maxes out at 44 deg. have changed all sensors except 02's. all sensor readings are normal incl 02. Even replaced pcm with reprog'd one.
Also have identical car with auto trans. Have swapped sensors to no avail. 2nd car is normal.
Bought this car with blown engine-replaced short block with low mi 98 2.2, reman 97 head. Engine starts right up no knocks, rattles or misses. Did compl tune up.
Where do I go from here?? VIC
May 6, 2008 at 12:53 PM
