Engine Mechanical problem
1997 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
Can you manually check the timing chain?
Wednesday, December 30th, 2009 AT 7:15 PM
MMPRINCE4000
MECHANIC
What engine? 2.2 or 2.4.
SPONSORED LINKS
Thursday, December 31st, 2009 AT 7:14 AM
SGONZALES10221
MEMBER
2.2
Thursday, December 31st, 2009 AT 8:22 AM
MMPRINCE4000
MECHANIC
Remove valve cover and put socket and ratchet on balancer. Rotate colocwise and observe valve movement, then rotate counterclockwise, valves should move, if they hesitate, then chain may be stretched.
