1997 Chevy Cavalier starting problem
130,000 MILES • 4 CYL • FWD • AUTOMATIC
SEAN00
Ok i got a problem. My cavalier just doesnt start. When i try to turn the car on, nothing happens. A few days ago it did the same thing, so i played with the shifter a little bit. Then it started. Do you guys think its a sensor or somethin not tellin the computer the car isnt in park?
Jul 29, 2008 at 8:14 AM
DOCFIXIT
  • 18,828 POSTS
Possible neutral safety switch. Next time try putting in neutral see if it starts. If have the switch checked and possible replace.
Jul 29, 2008 at 8:41 AM
SEAN00
ok so i tried that and it didnt work. So how would i know if that switch would b broken. And where is it located?
Jul 29, 2008 at 3:14 PM
DOCFIXIT
  • 18,828 POSTS
Look where shift cable hooks to trans right of engine down under some wires. Make sure connector is on tight ans switch is held down tight. @ cost of switch $65 and an hour labor aver. $95 per hr.
Hope this helps
Aug 3, 2008 at 4:38 AM
