1997 Chevy Cavalier starting
TRAMPLONG
1997 Chevy Cavalier
seems like no power going to starter. when clutch pushed in turn key to start and nothing. power to every where else good
Oct 4, 2009 at 11:14 AM
RHALL77
  • 3,361 POSTS
did you check to see if there is power coming out of the ingnition switch? also double check your fuses. did you check to see if the neurtal safety switch is working correctly
Oct 6, 2009 at 11:36 AM
