1997 Chevy Cavalier starter replacement
1997 CHEVROLET CAVALIER
TSAMANTHA84
1997 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
when the problem started i would turn the key and it was like a humming sound but everything was on in the car and on the outside of the car i had some one to check it and they found that the wire from my batter that connects to the started was lossen he tighten it but about 2 hours later the problem was the same. i had to turn key hold it and pat the gas and it started but when they checked it again he said the lug that connects to the started was lossen he tighten it but it cranks now but it still has the thing where its slow about starting up do i need another starter or do i need to replace that lug
Sep 3, 2008 at 3:52 AM
RHALL77
  • 3,361 POSTS
i think your are trying to explain to me is the post on the sloenoid is loose. i would suggest if that is the case just replace the starter.
Sep 3, 2008 at 10:21 AM
