1997 Chevy Cavalier squilling in front by pulleys of belts
182,000 MILES • 4 CYL • FWD • AUTOMATIC
PETRINA929
what can it be ???
Sep 24, 2008 at 10:25 AM
BLACKOP555
  • 10,386 POSTS
first thign i would check personally would be that the belt is properly tightened, not beyond the wear limit or glazed up.
Sep 24, 2008 at 12:07 PM
TRIZZYG
i have the same thing. i thing it could be a bearing in either the tensioner or the water pump...if it was the belt, a lite spray of water to quiet it would tell ya that. bearings, well, that's a lil harder because most are sealed for protection. helps to have a thin rod, much like a hanger, stick one end on the area you think it's coming from and the other touch with the palm of your hand...most faulty bearings will give a slight vibration...but you will definitely tell a diff when compared to all the other accessory pullies.
Sep 25, 2008 at 4:01 PM
BLACKOP555
  • 10,386 POSTS
you could also elect to take off the belt and rotate them/spin them by hand see if they have excessive noise and dont turn easily.
also shake them and see if they have play.
Sep 27, 2008 at 2:38 AM
