1997 Chevy Cavalier shutting off at random times
1997 CHEVROLET CAVALIER
150,000 MILES • 4 CYL • FWD • MANUAL
S2KFREAK88
hi my name is coby and I was wondering why my car shuts of at random times, like it works for a couple weeks then it will start acting up on me and i shut it off for a minute or two and it will start and run fine for awile. I talked to a couple of people and they were saying it could be the cam or crank sensor and i took it to auto zone to use the obd 2 and that wouldnt work as well so if you can help me or at least point me in the correct direction it would be greatly appreciated.
Dec 9, 2009 at 8:29 AM
MMPRINCE4000
  • 8,548 POSTS
Well if you are getting a check engine light, most autoparts stores should be able to give you the error code number and a partial diagnosis.
If engine loses ALL power and windshield wipers do not work, radio etc. Then it is most likely an ignition switch, neutral safety switch and a few other possibiities.
If just engine loses power, then could be cam sensor, ignition module, fuel pump/relay.
During one of these events, try spraying some starting fluid in engine throttle body, if it runs a few seconds, then problem is fuel related, if not then ignition and other items mentioned above.
Dec 10, 2009 at 5:26 AM
