1997 Chevy Cavalier Rocker Arms
150,000 MILES • 4 CYL • 2WD • MANUAL
STARCITY
  • 6 POSTS
Can you tell me how to Replace the rocker Arms on the 2.2 and if #1 Piston has to be at TDC on each cylinder or just for the number one cylinder and then change them all. I believe Torque is 22. Im replacing all with new Push Rods and Rocker arms as well as the Pivot Ball.
Nov 4, 2010 at 12:23 AM
WRENCHTECH
  • 20,760 POSTS
You can put them into position from any point but when it comes to torquing them down, you will get a more accurate torque if both valves are closed on the cylinder that your are tightening.
Nov 4, 2010 at 12:33 AM
