1997 Chevy Cavalier rear brakes locking
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHRIS1956
when applying brakes rear brakes lock up and release in pulsating way violently comming to a stop. If applied lightly it will come to a stop. Replacing drums and brakes didnt work . Seems to improve a little after the car has been run, but if you need to stop quick the rear end of car jumps and hops.Any ideas why this is happening . Thank you
Jan 28, 2010 at 9:16 AM
SCOTTY DEE
  • 592 POSTS
Did you replace the wheel cylinders? Is the rear anti-sway bar linked up?
Jan 28, 2010 at 9:27 AM
