Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cavalier
Brakes
Master Cylinder
1997 Chevy Cavalier Problem with the master cylinder brake
1997 CHEVROLET CAVALIER
180,000 MILES • 4 CYL • FWD • AUTOMATIC
RICARDOLASSO
MEMBER
1 POST
I have problem with the brake pedal, there's no pressure, no rose is changing and booster kit master and still no pressure.
Nov 26, 2008 at 12:29 AM
Experienced Mechanic
I have a few questions.
Is there any evidence that there is a brake fluid leak?
Did you bench blead the master cylender?
Did you check to see if the rubber brake hoses (front) are not expanding?
Was there an adjustment on the pushrod going to the master cylender?
Do the brakes work at all?
Nov 26, 2008 at 11:19 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
