1997 Chevy Cavalier Problem with the master cylinder brake
1997 CHEVROLET CAVALIER
180,000 MILES • 4 CYL • FWD • AUTOMATIC
RICARDOLASSO
MEMBER
1 POST
I have problem with the brake pedal, there's no pressure, no rose is changing and booster kit master and still no pressure.
Nov 26, 2008 at 12:29 AM
✓Experienced Mechanic
I have a few questions.
Is there any evidence that there is a brake fluid leak?
Did you bench blead the master cylender?
Did you check to see if the rubber brake hoses (front) are not expanding?
Was there an adjustment on the pushrod going to the master cylender?
Do the brakes work at all?
Nov 26, 2008 at 11:19 AM
