1997 Chevy Cavalier oil light intermitten
GREDFERN08
Noises problem
1997 Chevy Cavalier 4 cyl Automatic
I had the oil changed on my 1997 cavalier today because the oil light was coming on when I was sitting still and when I take off again it goes back out. The lifters are making a little chattering I think it may be the oil pump. I could use a little help.
Dec 22, 2009 at 3:33 PM
  • 31,937 POSTS
Hi there, the first thing you need to do is get the oil pressure tested with a mechanical gauge, do this and post the readings, cold idle, hot idle hot 2000RPM's.
Mark (mhpautos)
Dec 22, 2009 at 3:46 PM
