1997 Chevy Cavalier OBD2 scanner not working
90,000 MILES • 4 CYL • 2WD • AUTOMATIC
DARKDANZIG298
I have a check engine light on my 1997 chevy cavalier. I recently bought a OBD2 scanner for my car and nothing comes on when I plug it in. I also have a 2009 toyota sienna which i tried the scanner on and it worked fine. Is my problem in the ECM, if so what can I do to quick fix it.
Nov 25, 2009 at 8:17 AM
  • 31,937 POSTS
Hi there,
Some generic scanners wont work with all cars, i would try your scanner on a few other cars , to see how it preforms, i think you may find that it is the interface between the scanner and the ECU, just check that all the pins are clean and none feel loose.
Mark (mhpautos)
Nov 25, 2009 at 12:14 PM
