1997 Chevy Cavalier Left side headlights are dim, right sid
LEO11
  • 1997 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 147,000 MILES
The left side head light bulbs come on dim when the head light switch is turned on. The right side lights act in a normal manner. I have replaced the high and low beam bulbs, and the head light relay but I still have the same problem. Please advise me on what to do next. Thank you, Leo
Sunday, February 8th, 2009 AT 5:20 PM
MMPRINCE4000
  • 8,548 POSTS
Check voltage at both connectors with a multimeter, but it sounds like a bad ground/connection in the system.
Also clean both connectors with an electronics cleaner and use dielectric grease on connectors.
Inspect wiring harness to headlight for any worn insulation.
Monday, February 9th, 2009 AT 7:37 AM
