1997 Chevy Cavalier Leaks
COCO_30
1997 Chevy Cavalier 4 cyl Four Wheel Drive Automatic
When I wake up in the morning there is a little wet spot under neath the passengers side of the car near the top, What could this be? and also my windsheild wipers stay in the middle and do not go down, I mean they work fine, and when the car is off they go straight down but when its's back on they stay right in fron of my face on the drivers side. Do I need a new motor for the windsheild wipers?
Oct 21, 2008 at 9:49 AM
MMPRINCE4000
  • 8,548 POSTS
Is the wet substance coolant? If so it may be the heater core.
The wipers may be loose on the shaft or the gears stripped, or the connection to the wiper motor could be loose.
It is also possible the limit switch is bad.
Oct 22, 2008 at 1:57 AM
