1997 Chevy Cavalier Knocking noise
12,400 MILES • 4 CYL • 2WD • AUTOMATIC
BARCAR
When I put the car in gear, there is a knocking noise coming from the front right tire area. Doesn't do it when it downshifts or upshifts, just when put in gear. What could it be?
Sep 25, 2010 at 8:43 AM
  • 110,251 POSTS
Are you refering to the passanger side or driver's side?
Sep 25, 2010 at 4:37 PM
BARCAR
passenger's side
Sep 26, 2010 at 12:48 AM
  • 110,251 POSTS
Does it do it when the car is not moving? Have you checked motor mounts? Is it one knock or many? Have you checked the CV joint?
Sep 27, 2010 at 12:26 AM
BARCAR
Car has stopped knocking. Mechanic checked CV joints and motor mounts. A rock did fall out of somewhere during inspection. Thanks.
Sep 28, 2010 at 12:33 PM
  • 110,251 POSTS
That is an easy fix. I'm glad you found it.
Let us know if you have questions in the future.
Oct 1, 2010 at 3:37 AM
