1997 Chevy Cavalier Key won't turn - wheel not locked
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
JENNIFERBLUE
I drove my vehicle 5 miles and turned it off. When I went to start it 10 minutes later the key will not turn more than an inch. The steering wheel does not appear to be locked. If I attempt to press the brake I am met with resistance and I am unable to shift into gear. I have had the entire dash, instrument cluster, and key/tumber assemply replaced within the last year. The mechanics feel different this time. What am I dealing with now?
Apr 13, 2010 at 9:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check out our tips on this common issue at http://www.2carpros.com/first_things/why_wont_my_ignition_switch_turn.htm
Apr 13, 2010 at 4:08 PM
